Freep
Apr 14, 2021Explorer
jaycocreek wrote:
Lifepo4...
I expected, because I've read, that the volt meters for lead acid were not accurate with lithium,not from what I've seen so far...I haven't drawn it down below 50% yet but above that ,there all the spot on but only in tenths for the standard volt meters..It would be interesting to them then compared in the hundreths where lifepo4 volt readings should be compared to the charts..
Just for a general idea of SOC,there very accurate to the tenth.
That is odd. You're right, the volt meters for lead should not be correct with LFP.
Here's a LiFePo4 voltage chart
Here's a lead chart
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
