jaycocreek
Jan 08, 2022Explorer II
2oldman wrote:JKJavelin wrote:You won't know until a couple years later.
Still, a lithium battery with a BMS for under $300. Too good to be true?
Or you can pick one of the batteries Will P has torn down and compared that are in that price range..Other than the cold cut off,Will has recommended or commented that Ampere Time/Chins and Zooms are identical batteries internally except for the name on the case..Same BMS/cells and quality connections etc inside...
I think the Chins and Zooms are both under $320 last time I looked...
Jayco
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
