Oaklevel
Jun 21, 2015Explorer
AS far as the landing gear plug the 12V light/power cord into your tow vehicle it should have a 12V hot pin and the landing gear should work, if the motor is not fried, should go up, or you could blow the fuse on the truck but it is worth the try. Be sure to see that the taillights still work as well.
If your converter is shot you will not get any inside lights but the exterior 12V lights tail / turn signals Etc. should still work.
Good Luck !!!!
Good Luck !!!!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
