Horsedoc
Aug 11, 2019Explorer II
You will think I am nuts (you may be right!) cut a small slit in a tennis ball and then run a screw with washer through from the inside of the ball into whatever the door is slamming against. The ball will have some 'give' but won't bounce the door back nor dent the door.
