christopherglen
Sep 10, 2014Explorer
I have used SSR's (usually crydom) for many projects, usually when I need minimal switching power IE a battery device switching something with it own power supply. Or optical isolation of the switch, or insanely high switch speed / durability.
For general switching in rv's I tend to use relays.
For example
SSR's have a .5 to .75 volt drop across them, hence the need for a heatsink several times their size. At high loads, what you save on switching current, you loose on load voltage.
For example
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
