JHblack
Aug 09, 2021Explorer
KD4UPL, I understand your statement on batteries. I did not clarify it very well. Batteries are new Interstate Batteries and when this s&#t Show started I checked batteries immediately and found that they were week (not fully charged) so I charged them for several hours and then they were back up to normal and were holding a charge. I even load tested both after charged and they were Good.
I hope this clears it up for you. Sorry.
I am planning on pulling out wall underneath this AM and get in CONVERTER so I can examine and test fuses. If fuses are toast, then easy fix. If not then it’s still under warranty and I’ll let someone else deal it. I’m only trying to figure this out so if next time, outside of warranty, if the event happens then I know the cause. Just hate dealing with dealer, warranty or not Because they are normally 3-4 weeks out from beginning to end.
On a side note, I’m assuming that KD4UPL is a call sign for HAM?
