mbopp
Aug 02, 2014Explorer
Lippert Electric Stabs
Just an observation....
These came on the TT from the factory. When setting up on uneven ground they're designed to rock side to side to compensate for it.
But - this same feature also allows the TT to rock side to side (or roll) when moving around inside it or getting in and out. The system isn't as stable as having individual manual stabs on each corner. I think I'm going to try putting a jackstand under the frame on each side near the axle and see if this helps.
I wish there was a way to lock the pivoting mechanism after the TT was all set up.
