frankandrews's avatar
frankandrews
Lippert Level up system
I have a 6-point Lippert level system on my 5th wheel Toy hauler. When we are parked and set up, you can here the leveling system make a popping noise once in a while. After a time I eventually have to re-level the 5th wheel. Is this leak down a normal function or what should I be looking at/for? Should I keep the trailer leveled when it is sitting next to the house?
  • Mine did that all last summer while we were camping at 8,300 feet. Since then nothing. Altitude?
  • Sounds like a system leak. Could be internal or external. No way to know for sure until you do a complete external inspection. It could only take a few drops to cause you a problem.
  • It sounds like you could have a valve leaking. I just dealt with the good folks at Lippert for a problem with my Power Gear leveling system. I strongly recommend getting in contact with their customer service department and seek their input. The tech that i worked with knew so much about my system I thought he was one of the engineers that helped design the system. He knew exactly what to look for, no runaround or guess work.
    My experience with them was , they reacted fast, went out of their way to help resolve my problems and then followed up to make sure I was 100% satisfied.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
