When this happens and it make no difference if LCI or Equalizer or any system that uses a pressure switch to activate down indicator---It is always the pressure switch. They do have updates for some switches. They also have an extra port on the manifold to ADD a extra switch when this problem happens. It all depends on the Year model and model of the Pump system. IF no fluid leaking on the ground, you have a pressure switch problem. Doug
https://lci-support-doc.s3.amazonaws.com/technical-information-sheets/leveling-and-stabilization/ccd_0001900.pdf
