garyemunson
Dec 28, 2018Explorer II
Lippert Levelling leakdown
Anyone else have the issue of Lippert levelling system leaking down just enough to trigger the auto-retract whenever the parking brake is off (parked or driving). Cannot see any motion on any jack and I realize just a tiny internal leak will drop the retract pressure enough to start the pump again. This has been an issue with 2 sets of jacks (first set replaced under warranty for noise that the suggested anti-stiction fluids would not cure) so unless I happened to get another jack with a bad internal seal, I'm expecting the issue is somewhere on the pump and controller. Any suggestions on how to go about troubleshooting this intermittent problem? Should I just start by replacing the pressure sensing switch? As the light and alarm go out when the pump builds up pressure again, I'm thinking the switch is probably operating OK and the problem is at some internal valve.
