Rob_Fla
Jan 10, 2018Explorer
I have had both the electric and the hydraulic leveling systems, they both worked well.
The hydraulic is fast and powerful, it is lots of hydraulic hose and cylinders that may leak.
The electric is slower than the hydraulic but it is also quite powerful but no issues with leaks.
The hydraulic pump can be operated manually if the motor fails but if a leak occurs you have a problem, the electric can be operated manually at each leg if a landing leg motor fails.
In a aftermarket installation it would seem the electric would be easier to install since you only need to run electrical wires instead of hydraulic lines to all the legs.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
