joshuajim wrote:
dougrainer wrote:
Some Slide rooms run along the carpet. Those types are NOT designed to have tile/Lino under the slide. Nobody uses a small edge of carpet to support a slide room to keep from damaging the tile/lino. While you can use Carpet to stop that type problem, that is not a design. You state a LCI slide room. That does NOT tell us what model LCI slide room mechanism you have. They have quite a few with different parameters. Doug
The manual I received does not specify a model number only that it is a Lippert electric slide out system (rack & pinion).
I beg to differ about the flooring.  My unit came from the factory with vinyl floor that extends under the slide floor.  The slide floor extends about 4” in front of the assembly with carpet wrapped over the front and tucked under the slide floor.  The carpet is DEFINITELY used to support the slide.  I guess I could have the only one made that way.
You have the carpet on the top of the slide room floor wrapped around and on the bottom. THAT is normal for your type lino. From your description previously, you made it sound like the carpet was on the MAIN floor of the RV. Your pic shows the normal way they did the carpet. The carpet does not really support the slide, the Rack/Pinion does. The carpet is what keeps the bottom of the slide floor from damaging the Lino. If GLIDES across the Lino. Doug
