AV8_Tuna's avatar
AV8_Tuna
Lippert Slide-Out extends but does not retract
Road Warriors,
I have a new to me 2007 HR Alumascape 5th Wheel. It has Lippert through frame electric slide outs. My living room slide will slide out fine but when I try to retract it nothing happens (I press the switch and nothing, the motor doesn't try to spin). I have to manually retract it a few inches then it will retract via the switch/motor just fine (plugged in to shore power, battery at a high state of charge). I have swapped the switch out and it still did it (I swapped the living room switch with the kitchen switch. The living room, with the kitchen switch, would not retract and the kitchen, with the living room switch, would extend/retract fine). I'm at a loss, the work around is ok for now but ideally I would like to be able to retract the slide with only the motor and not have to do the partial manual retract thing. I originally through the actuator arm was over extending so I adjusted where it connects to the slide out so it did not extend as far but this did not help. I appreciate any advice or recommendations. Thanks in advance.
-Marc
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
