I have the Lippert auto-level and it works as advertised. If it is too far out of level (front-to-back or side-to-side) to operate, it displays a message to that effect on the control panel. (This usually only happens when I have just unhitched on a front-to-back downhill slope and the nose is too high. I lower the front jacks manually and then auto level will work.) I've never had a problem auto-leveling side-to-side, but sometimes, the wheels on one side do end up off the ground. Nothing to worry about. And sometimes I do have to put blocks under some of the jacks.
Given the prior swapped connections, I suspect a problem with the system. Take it back to your dealer and setup an out-of-level situation. (Blocks under wheels on one side.) Then if it fails, the dealer can see that there is a problem with the system. (When I bought my new 5th, there was a problem with the control panel, and it had to be replaced.)
