Bert the Welder wrote:
And just for the sake of wondering.... for temps that cold, could some sort of heat pad, blanket or bag not be used to keep the lith's warm enough to function properly? (I'm picturing a Domino's pizza delivery electric warmer bag) Or, perhaps, would moving your batt's inside your camper living space. Obviously if you go with the SiO2, your good to go. But for those with Lith's already, are there options if they are occasionally stuck in temps that cold?
Or mount them inside the trailer instead of outside, which eliminates the low temp operation issue and increases security. Or buy one of the brands that has internal heaters or use the heating pads offered if you'd prefer to keep them outside. The entire temperature argument is a non-issue in my opinion.
