theoldwizard1 wrote:
The "safe" answer is no !
That is indeed the safe answer however....
I've seen lots and lots of posts about batteries especially different size batteries that are 100% ... ****. no other way to put it.
Good chance your 200 amp battery is two 100 or 4 50s in the same box.
(Not 100% by any means but I have seen it).
The Myth "Well as the batteries run down the 100 amp will run out while the 200 is still half charged".. BULL, total BULL
Though LiFePO4 do not drop voltage like Lead Acid do as they run down (Till they hit empty then they do the rock in freefall thing) they do... very very slowly.. drop voltage as they discharge.
And the battey with the greater state of charge (Voltage) Will supply the power UNTIL it's at the same SOC as the other battery.> Then they will "Lock" together SOC wise..
Same with charging.. If one is at a higher state of charge it will not accept much till the other one catches up. then they "Lock"
HOWEVER in the case of different LiFePo4.. there is the Battery Management System... How well they are designed may affect the results.
I plan to put in 3 100 amp's some day (This is planned for next year) to replace 300 amp hours of Lead Acid.. But I got to pay for Christmas first (Actually it's paid for but I blew my cushion).
