pianotuna wrote:
S Davis,
So what are the components in your battery bank? Which battery management system?
Here is most of it I am adding a victron multiplus or a outback 3000 watt inverter.
600amp buss bars
4/0 DLO cable rated at 405amps from the 600a buss bar to battery switch
3/0 DLO cable from the batteries to the negative 600amp buss bar
600 amp dual bank battery switch/one on, both on or both off
3/0 DLO cable rated at 350amps from switch to each 280ah battery
300amp MBRP fuses on the positive of each battery
Battery buss bars rated at 300amps
Daly 250amp 4-S BMS
There is also a heating system on each battery with 25 watt silicone heat pads and fans, I keep them about 50 degrees F.
