lem55
Nov 27, 2022Explorer
Lithium batteries
Hi all, Quick question. I have asked some of the sellers, but have not gotten a response. My question is can you mix battery amperage 100 amps with a 200 amp battery? Thanks Lee
pianotuna wrote:time2roll wrote:pianotuna wrote:Or the BMS stops the charging at low temperature and protects the battery until it can be determined why the heating system has failed.
The \"cold\" end is the dangerous part. Charge below that, and the batteries become expensive door stops.
You left out part of what I said which was there is no need to have heaters cut in at 50 f.
