otrfun
Dec 10, 2022Explorer II
theoldwizard1 wrote:Specs vary from manufacturer to manufacturer, but generally speaking, maximum recommended discharge current tapers downward as temps drop below 32f or so. Probably wouldn't want to do more than a .10c - .15c discharge at temps below, say, -10c (14f).
. . . What I don't know is if below freezing will affect the battery life while discharging or storing.
Long-term storage recommendations are not too stringent. If you follow the temp recommendations for charging (typically 0-40c; 32-104f) that should be acceptable. If you want the absolute best for your cells, strive for 25c (77f) and 30-50% SOC.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
