BFL13 wrote:
No problem with a Wet or AGM 24 in parallel with a 27 with different AH. They rise and fall together in SOC.
What I was referring to was in the context of FLA’s (a segue from P-tuna), and although anything is possible (and likely has already been attempted somewhere by someone - e.g. two series sixers in parallel with one 12v, etc), I believe that the mixing of batteries is not the best practice, JMO...Note too, that I made no speculation as to mixing different capacity LiFePo4’s (nor do I have plans to do so...), but I’m all ears!
3 tons
