"If you're thinking of adding 100ah batteries to larger ah capacity batteries your going to run into problems. Yes, they are the same voltages but the lower capacity batteries will shutdown before the larger capacity batteries. The bms's could be setup differently protecting the cells of the different packs. Stay with the same ah capacity battery"
Please explain. I asked about this earlier in this thread, but no answer.
No problem with FLAs so why with Li is the question. (FLAs do not "shut down" eg.) Is it because of BMS? Is the BMS in the same brand 200 different from the BMS in their 100, so they shut down at different times?
If so, why pick the 100 to shut down first? What does capacity have to do with it, when it has no effect with FLAs?
Just like to know and maybe others do too. Thanks.
