3 tons wrote:
I’m relatively new to Victron's BMV Li compatible SOC meter, but prompted by my previous, I then checked the Victron BMV Manual and found this item of high interest in Section 4.2.2 concerning relay programming - For those who have this device, this seems the ideal solution to end-of-charge shutting down of the Li’s charging source post BMS balancing regiment!!
“15. Relay-off delay
Sets the amount of time the ‘de-energise relay’ condition must be present before the relay opens.
Application example: keep a generator running for a while to better charge the battery (relay in CHRG mode).
Default Range Step size:
0 minutes 0 – 500 minutes 1 minute“
Many thanks, Victron!
3 tons
Really good to know this, sir, thank you. I have one coming and soon to be installed as the first step in the process - LI upgrade, then, perhaps, add 340W solar and an MPPT Controller...
