Old-Biscuit
Oct 05, 2015Explorer III
NO flow of HOT water thru hot side of faucets/shower.......check valve on water heater outlet stuck closed/jammed/clogged. ALL hot water comes thru it>
Luke warm/cool water flowing out of hot side of faucets/shower....then water heater bypass valve is open or leaking thru enough that cold water is going into hot water line making it luke warm/cool (check valve on hot out closes/reduces flow due to cold water flowing into hot line)
No hot water flow thru just one fixture......local problem with that fixture
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
