westend
Oct 16, 2015Explorer
is there a flow check valve on the hot out flow if so where is it located I can not locate itIf you have one it may be threaded into the hot water tank. Look for a larger than usual fitting on the outlet side.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
