CharlesChmielow
Oct 16, 2015Explorer
My no flow problem is solved on the Journey 39K models they put the hot side check valve behind the water service panel in the line that goes from the water heater to the water heater bypass valve and to access the check valve you have to disassemble both pieces of the panel thanks to all of you that responded I appreciate the help
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
