CharlesChmielow
Oct 18, 2015Explorer
I solved my no flow hot problem I called Winnebago tech support and they directed me to look behind the water service panel for the check valve and sure enough there it was nestled in the plumbing behind the panel to replace the check valve required disassembly of both pieces of the water service panel so if you own a Journey model 39K your hot water check valve is located behind them water service panel because there's no room for it at their water heater outlet
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
