j-d
Jan 06, 2014Explorer II
Our gray and black tanks were dumped, so I drained the fresh water tank, low point drains and water heater. I need to go out and drain the inside and outside shower. If your heat is ducted into the tank areas, you should be good. Our waste tanks are under the coach, and the fresh tank is too, above the rear axle, so running heat won't help in our case.
Would be interested in hearing what others are doing.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
