John_Joey
Jan 06, 2014Explorer
joebedford wrote:John&Joey wrote:Why? If you're heating the water it's not going to freeze.
make sure you drain your hot water heater.
Very true, but why would you heat the water if you drained the system? I would not run the chance that the hot water heater was full if I pulled a low drain plug.
You stand a chance that a siphon might have pulled the water down in the tank exposing the element, or putting the safety sensors into a dry environment.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
