Harvard
Jan 07, 2014Explorer
Dennis M M wrote:
Back to the original question, you should be OK if your storage areas or tanks are heated. Disconnect your water hose and run on your fresh tank. We did several consecutive days with highs in the teens and lows under 10 in Colorado this fall with no issue.
FL may be like AZ where the water bibs are not protected. In that case leave your fresh water hose connected, your gray tank open, and run a trickle of water in your sink all night. We've done that at 18 degrees in AZ with no problem.
Take care to insure the sink with the running water trickle DOES NOT drain into the Black Water Tank...been there, done that! :B
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
