lawrosa's avatar
lawrosa
Load C to load D tire inflation?
So I have Jaxxon tires now on the RV. Rated 81 mph load C @ 1760 each.
205/75 r14 @ 50psi
Note: Im not upgrading rims, tires to 15". No way. Cant afford it.
The tires are ok. Seems wear for only 5000 miles is a bit off if you look at the tire. You say in your mind and ask the question to knowledgeable people , " Do these tires look right to you?"
So to replace of course not going with jaxxon... But choices seem to be something like
Taskmaster load C. Has 2 year warranty and 81 mph rated 70 bucks
Westlake load C. 5 year warranty (wow) but a 75 mph rating. 80 bucks.
Now I do like the endurance tires from GY. But they only come in load range D. These are 65 psi tires.
If I went this route I dont want or need the capacity. Its a 7000 GVW trailer maybe loaded to 5500 lbs max fully loaded. Lets just say I can get it up to 6000 lbs for giggles.
Also note the dry weight was/is 4730lbs. No way to fit close to 2200 lbs in any of the available storage areas.
So GY inflation tables shown here show I can do 50psi for the same 1760lb rating as c rated tires.
GY endurance inflation tables.
The question. How will lower PSI affect the tire regarding heat?
I was thinking maybe running 55 psi in them. But I dont want the trailer bouncing all around.
Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 27, 2025
