tkcas01's avatar
tkcas01
Locating Cell Phone Towers
I just recently purchased the Wilson SignalBoost DT for use in my rig. For what it is worth, I got it to replace the Digital Antenna PowerMax 4KMR-30U that never really seemed to help much. Maybe it was defective from the start - hard to know.
Anyway, so far I am impressed with the Wilson. I am in an area with a poor signal and it is definitely doing its job. Thing is, this Wilson has a directional antenna for outside and you are supposed to aim it toward the cell tower. I am wondering if anyone has found a reliable way to find the location of the nearest Verizon tower?
I found this site called Antenna Search. I was hoping to find a mapping application that would plot the towers, but what this does is let you download a spreadsheet with info on nearby towers. It's pretty easy to copy and paste the lat/long into Google Maps and see where they are in relation to you. For the one nearest me, when I zoomed in the satelitte image the location was spot on.
Anyone have a better way to locate nearby cell towers as you roam around the country? (And no, I don't mean by driving around and looking up!)
UPDATE FROM OP
Actually, Antenna Search does EXACTLY what I was looking for - the UI just leaves a bit to be desired and you have to know where to click. I must have clicked "Download Records" and that gives you the spreadsheet. Right above it is a button that will open a window with the locations plotted on Google Maps! Cool.
For example, here is the report on my current location. Still doesn't tell you which carrier uses the towers, but at least helps zero in on them.
On the Wilson, you also have to be careful that the inside antenna is NOT between the outside antenna and the tower. For example, if I mount the outside antenna on the rear ladder and the cell tower is to the front of the rig - that would be a problem. So, knowing the locations before getting set up will be a big help.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If you have a smart phone and it can get a connection at all.. There is an application I have on my 'drod called Network Signal Info.
    It will ask the tower where it is and post the response.
    NOTE: I have seen the towers up to a half mile from where it claims it is.
  • vermilye wrote:
    if you use 4G data, this & most of the currently available models don't cover the 700Mhz LTE frequencies.
    Yep, I can get by without 4G, but a phone that can't phone I cannot.
    I thought about also getting a 700 Mhz booster, but I think I can make it without it.
  • The repeater systems are handy since they allow you to move around inside the RV with your phone, but if you use 4G data, this & most of the currently available models don't cover the 700Mhz LTE frequencies.
    I have the same problem with most of the tower locating programs - since most of the space on the towers is rented by the major cell providers, it is almost impossible to identify who is where.
  • Might be another way, but easiest/cheapest way would be to SLOWLY turn the directional antenna around the circle and watch the phone bar display. You will know you got it right whichever direction you get the most bars.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
