Son_of_Norway's avatar
Jul 10, 2020
Locked out of RV
This concerns the door latch below the deadbolt. I have the key. I have no problem locking and unlocking the latch, but I can't open the door with the outer latch. I pull on the latch and it won't open the door. The door isn't jammed, it acts like the latch is still locked.
So, I am locked out of my RV. All the windows and other ways to get in are closed and locked. There are no compartments or other ways to get in. I don't mind ruining the latch to get in, it needs to be replaced anyway. I have drills and other tools. I don't want to break a window.
What can I do?
  • I was on my third handle when a friend told me about a repair kit for the Trimark handle that I have. (T507/060-1650) I have bought 3 of the kits, and they're great. Takes 2 minutes to install, made out of stainless steel, and now I have 2 spare handles if someone else has the same problem. They're listed on Ebay.
  • He has a website cartcollapse.com that has a link to buy using PayPal.
    What can I do?
    Try pushing in on the door hard and pulling the handle or push in hard and use the key. Facility used the dead bolt yesterday instead of the fob and it didn't want to open.He came out and pushed n rel hard, the seal has a lot of compression, and I used the key and it opened right up.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    My Tri-mark latch is a bit different than that but I had a shop make me a new striker bolt when the last one broke... Price for the one in the kit is reasonable
    On my basement doors (Also tri-mark) slightly different bolt. Seneca Engineering in Seneca, SC carved me a batch of 'em I think about the same price.. Can't find the dang things so I used Plan B a few days ago.. (one of the many jobs I've held.... machienist.. I machine down the parts. mark, drill, tap and apply a standard steel mending bar to the "Backside (The long flat side) works great)
    Thank you!
  • (I'm intentionally cross posting this to get the info out)
    Same Problem, Best Solution!
    After some research I purchased a Trimark Latch repair kit and I'm pleased with a complete and permanent fix for $49.
    The kit includes a steel replacement piece, wrenches you'll need for the fix and a new spring, in case you lose yours like I did. This allows you to use your existing keys and it installs with no "modifications" needed which may not be the case if you just buy a brand new Trimark Lock.
    To be fair, I have read that the new Trimark locks use a steel latch piece rather than the crummy pot metal ones that break.
    The cartcollapse.com website doesn't seem to work anymore. Here are links to the Latch Fix website and the video showing how easy the fix is to do.
    https://www.latchfix.com
    https://www.youtube.com/watch?v=efW38pxwzZI
    Cheers,
    -Grouchy
    Agreed. Pulling on the handle pulls on the door, which is already being pushed by the door gasket, making the bolt more difficult to move. I use more of a rotation than a pull.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
