azrving's avatar
azrving
Long charge time
First I want to thank Roy, Mex, Piano and others for posting good electrical info on here.
I have now installed a PD4655 converter, 4 new 6 volts, 6 gauge wire from converter to batteries and battery wiring is balanced.
Over the weekend I ran the batteries down to 12.1 and put it on charge at about 6:00 pm. It went into boost mode and I was reading 14.2 at the converter. I was reading 13.3 at the battery bank. I checked the converter as directed by PD tech and it has the ability to put out 14.42. I placed a temporary 4 gauge cable straight from the battery to the converter and it reduced the voltage drop from .9 to .5
When I checked it at the converter last night at 11:00 pm it was 14.25. When I got up it was in normal mode with a fast flash and 13.6
Before starting the charge the SG was 1.230 and it is now almost 1.250 So I have moved the SG less than 1/2 way and its been 16 hours. I know it wont put the SG at 1.275 in 4 hours but something is wrong. The only thing I can think is that the charger needs to be VERY close to the batteries or I need 2 chargers?
It also has good shore power with full voltage. I plan on running a generator this winter so I need to get the fast charge time.
Thanks for any ideas.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
