horton333's avatar
horton333
Long Question on how Converters Sense Battery Voltage.
Hi:
My normal 2 weeks per year of dry camping will be more like 2 months this year I expect so I am investing in a better 'off grid' setup and the single output voltage converter has to go. For reference 220 AHs of AGM will be the battery. Hence two, one rather detailed, questions.
Questions 1:
Researching converters there seem to be several good multi-stage models on the market, but there is one thing that is bugging the EE in me. There seem to be two major classes. One class have an internal transfer relay, and when on AC the battery is charged by a separate circuit board thru an isolated circuit. The issue is these all seem to be far low amperage for my setup as I really want no more than say 2 hours per day charging (75 AHs is what I guess I need per average day).
The models that have the 75-100 Amps I want all seem to have a single 12 volt output and this is shown in the manuals as going to both battery and the 12 volt accessories, so this leads to question 1. With some of the load being the battery and some being lights or whatever (and variable) how does the charger know when to scale back the voltage when fully charged? If it just guesses on current draw I can see it never coming off 14.4 volts. Is there something I missed that allows them to accurately know where the battery charge level is at to lower the voltage when charged or _______? If the AGMs can handle sustained 14.4 volts, my motorcycle which puts out 16 volts leads me to believe they may be able to but the manufacturers seem to say no, then maybe I would get almost the same result (its only 55 amps, a waste with all that battery capacity and a 2.2 kw generator)by just cranking the voltage on the existing converter?
Question 2)
I have not seen any units that have remote voltage sensing, only temperature. Do you know of any out there that sense the voltage at the battery?
John
  • MEXICOWANDERER wrote:
    I like the model that has the "Frontal Lobes" option...
    Don't buy anything unless it has "thunder protection" and a re-settable breaker for that.
  • They all sense voltage at their own output terminals.
    Progressive Dynamics uses a timer to reduce voltage.
    IOTA drops voltage 15 minutes after hitting 14.6 then uses a variable timer to go to float.
    PowerMax drops as soon as it hits 14.6 volts.
    For best voltage sense install the new converter close to the battery with #4 wire.
    For true flexibility you need a good solar controller. They have all features you need.
  • The battery only "accepts" the amps it can handle, so the charger's voltage can remain the same while the battery is actually self-controlling what it uses.
    When the 12v system has various loads running off the converter, they get first call on the output and the battery gets whatever is left over. (proper explanation is wrt the voltage differences between the loads and the converter being more than the difference between and the battery and the converter---or something like that!)
    Modern converters do not have that transfer switch thing or relay like the old Magnetek 6300s. Your choice is between a single stage or a multi-stage modern one and how many amps size. Note that the amps size limit is how many watts (VA actually) your generator can do
    If you get a power factor corrected charger you can do more amps size on the same generator. In the 75-100amp size range, the PowerMax converters do have PF correction. Other brands like PD and Iota may have features you want instead if generator is not the limit.
    Mex here, has noted that you do get more amps even with the single stage converter because AGMs accept more at the same voltage than Wets do, which is interesting if you are choosing to upgrade from a single to a multi just to get more amps and you now have Wets. of course you can do both--get AGMs and the multi.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
