Fisherman
Jan 18, 2022Explorer
dougrainer wrote:Ex-Tech wrote:
Cover the burner up and remove the roof vent to access the flue tube and use a wire brush with a long wire handle. (These are available at HVAC supply houses).
Push and pull the brush up and down a few hundred times to remove the rust. ;)
What do you do about the spiral baffle??????????????? Doug
Once the roof vent is off, lift up the spiral baffle and clean it off.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
