jrnymn7
Feb 03, 2015Explorer
Model Tracer1215BN Tracer2215BN Tracer3215BN Tracer4215BN
Nominal system voltage 12/24V auto work
Rated battery current 10A 20A 30A 40A
Rated load current 10A 20A 20A 20A
Max. PV open circuit voltage 150V
Max. battery voltage 32V
Max. PV input power 130W (12V) 260W (12V) 390W (12V) 520W (12V)
260W (24V) 520W (24V) 780W (24V) 1040W (24V)
Equalize charging voltage Gel: 14.2V, Sealed: 14.6V, Flooded: 14.8V,USER: 9~17V
Boost charging voltage Gel: 14.2V, Sealed: 14.6V, Flooded: 14.8V,USER: 9~17V
Float charging voltage Gel /Sealed /Flooded: 13.8V, USER: 9~17V
Low voltage reconnect voltage Gel /Sealed /Flooded: 12.6V, USER: 9~17V
Low voltage disconnect voltage Gel /Sealed /Flooded: 11.1V, USER: 9~17V
Self-consumption ?50mA(12V) ?27mA(24V)
Grounding Common negative
Temp. compensation -3mV/C/2V
Communication Port RS485 / RJ45 interface
Working temperature -35C - +55C
Storage temperature -35C - +80C
Humidity ?95% N.C.
Enclosure IP30
Overall dimension 196x118x36mm 217x143x56mm 281x160x60mm 303x183x64mm
Terminal 4mm2 10mm2 16mm2 25mm2
Net weight 0.9kg 1.5kg 2.3kg 2.9kg
Humidity ?95% N.C.
Enclosure IP30
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
