BFL13
Feb 04, 2015Explorer II
jrnymn7 wrote:BFL13 wrote:
Since the voltages are adjustable in "user", between trips you can pick the same voltage for absorb and float. Then the timing doesn't matter.
Smk is always asking about that time in absorb! :)
The "default" charging profile is the standard EP Solar one I had a couple years ago in the LandStar with that two hour fixed absorb time. The RN series has that too. This new BN series brings the "user" feature plus an extra 50v from 100Voc limit to 150Voc limit.
Trolling eBay.ca, I found the 40a, 4215BN with the MT50 remote and cable for $285 (Can) free shipping.
Don't know the price for a BN 20a, but a 20a RN with remote was $165 free shipping. A 20a Eco-Worthy is still about $100 but has 42Voc limit vs the 100Voc in the RN.
BFL,
Do to parking at work etc., I've had to re-think my set-up, and I now plan to do a roof top install, c/w tilt and twirl (and a custom vinyl cover to keep the snow and ice off when necessary), and probably MPPT. But I'm still not sure whether to go series or parallel (yes I know I would be better off with 24v panels now, but smaller, lightweight portable may still be in the not so far off future).
Correct me if I'm wrong; if I go MPPT, which ever way I wire is irrelevant, seeing as both will result in the same power output in watts (your favorite subject). Considering temps, rainy weather, etc., it seems if I go series I would have 35v x 8a for 280w, and if I go parallel I would have 17.5v x 16a for 280w. And on a rainy day, when amperage would suffer greatly, at say half, I would have 35v x 4a, or 17.5v x 8a, for 140w, either way.
The only other thing would maybe be the issue of shading or partial obstructions; which if I understand correctly, would indicate series wiring would be best?
It is all situational, so you are on your own there! :) Where the camping situation wrt shading keeps changing at each location and it is for all year with roof mounted panels you have to do a giant compromise, which means being wrong all the time :)
I would look into arranging some kind of wiring scheme that can be switched back and forth easily at combiner point between parallel and series with also switching between controller types if you have one or more of each type.
If you have the 12vs in parallel I would just use the PWM. If using 24v array (12s in series or just big panels) you must use MPPT on a 12v battery. But you can also have a 24v battery and use the PWM if it is 12/24. You can get the 12v from the 24v battery bank separately.
With 12v panels you need fatter wire from panel to controller than with 24v panels which have half the amps on that path. From controller to 12v batts the wiring is the same with PWM and MPPT because your amps are back up to 12v level. If you have 24v batt the wiring can stay thin at half the amps. Then you need the fatter wire for the 12v part after that unless it is a short run of course.
I have no clue about shading since there are so many variations on how much by what on what. I have figured for camping in the open "up here", if I had two 12s, I would go MPPT in series in the cold half of the year and PWM in the warm half. I would not get MPPT for the cold half on 12v in parallel but if I already had the controller then I would use it. I sure wouldn't fork over $300 for one for that, when I already have a perfectly good Solar30.
I only have the MPPT because I got a 230w panel and I only got that instead of two 12s because it was almost half the price for the 230w. I could also get the Eco-W for its low price where in that one case at the time, MPPT over PWM controller cost was bearable.
If you have two 12s, the question is whether you want the Tracer for little benefit in AH over the Solar30 or because you want to mess with MPPT as a hobby for entertainment. It is cheaper than golf or fishing! :)
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
