NinerBikes
Feb 07, 2015Explorer
jrnymn7 wrote:
Concerning controller efficiencies, it seems to me,
With 280w (2x 140w) of 12v panels in series/mppt, if the mpp of the panels was found to be at 8a and 17v, that's 8a x 34v = 272w input. At 96% eff., that's 261w output. If the bank was at 12v ocv, and charging began at say 13v, that would produce 20a of charge current (261w / 13v).
With 280w parallel/pwm, if Isc was 8.5a, and panel voltage was pulled down to 13v, that would produce 17a of charge current (2x Isc); so 3a less than with mppt. Assuming the pwm operates with 100% eff., the input and output would both be 221w (17a x 13v). 221w / 272w of available power = 81.25% eff.
In hot conditions, as Vmp goes down, pwm efficiency would go up in comparison; and vice-versa.
Why would panel V be pulled down to 13V? With PWM, you are interested in Isc in amps, or 8.5 amps per panel. You assume the batterier can take that full 17 amps. Sometimes it can, if below 85 to 90% state of charge.
You are making this too complicated for winter time use in Canada, you're going to have short days, and need a generator to get the batteries back up to close to full charge.
Seriously, jrneyman, you are over thinking this. Go PWM and add another 140W panel, for 3 of them, and then pick whatever your heart desires for a charge controller.
If it's under 30 Amps at 12v, go PWM, if it's over or you have long runs of wire, go MPPT with 28V or more from the panels.
Or just buy the damn MPPT, experiment with it, and then get back to us on how it worked out, be the guinea pig.
Everything is a trade off, you can't have it all, so pick what's most important to you, make a decision, and spend wisely.
My decision was to have enough panel to stay in bulk charge, have a pwm controller that I can set at 15.0V for bulk, and since I know my unit just idle sucks 24 amp hours a day, I was sucking an amp an hour while dark, empty, or 14 to 16 amps in winter. Turn on lights fan, TV and of course the consumption increases. with short days and northern lattitudes, you may need a factor of 2 or 3x the watts to amp hour ratio that most consider normal, ie 1 watt of panel to 1 amp hr of battery.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
