Salvo
Feb 07, 2015Explorer
You would get a failing grade if that was an exam question. When using mppt, temperature is a killer . You didn't account for it. At 1000W/m^2 irradiance, the panel will be fairly hot.
The math has been done many, many times. mppt should have about 5% advantage.
jrnymn7 wrote:
Concerning controller efficiencies, it seems to me,
With 280w (2x 140w) of 12v panels in series/mppt, if the mpp of the panels was found to be at 8a and 17v, that's 8a x 34v = 272w input. At 96% eff., that's 261w output. If the bank was at 12v ocv, and charging began at say 13v, that would produce 20a of charge current (261w / 13v).
With 280w parallel/pwm, if Isc was 8.5a, and panel voltage was pulled down to 13v, that would produce 17a of charge current (2x Isc); so 3a less than with mppt. Assuming the pwm operates with 100% eff., the input and output would both be 221w (17a x 13v). 221w / 272w of available power = 81.25% eff.
In hot conditions, as Vmp goes down, pwm efficiency would go up in comparison; and vice-versa.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
