Chris_Bryant
Nov 15, 2015Explorer II
Have you ever installed one? Every replacement connector except the Progressive uses a simple screw to terminate the wire- it is a huge pita to get a #10 stranded wire all under that screw. The Progressive has a captive type termination- you stick the wire in a pocket and a set screw tightens against it- much, much better. The case is also not much larger than the molded. Plus, it's made in the USA.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
