SGTJOE wrote:
I just had my old Dometic NDR1292 removed and had a Magic Chef installed. I was really happy until I found the User's Manual and read " Now if this wasn't enough it also stated "ambient Temperature below 50"F or above 85 F will hinder the performance of the appliance. Working with dealer for not telling me.
So I'm looking for suggestions as to what residential fridge would work I need to be able to have a counter depth one where I can open the door to a max of 50 inches. Width 32 inches and height not to exceed 62 inches.
For those of you who have residential fridges in your RV can you send me the make and model number. I might be able to work with the height.
My MH is a 2001 National Tradewinds model 7390.
Sgt Joe,
Were I you, I would leave what you have right where it is....
Because: (Let's tackle that first paragraph)
"not designed to be installed in an rv or used with an inverter"
It is not designed to be installed in a RV because 5ers and TT bounce down the road and they never included vibration in their testing. The back of some Cs can get rough, but if your Tradewinds got that rough, you would have to plan to collect the dishes at every stop.
Or used with an inverter....
If you have enough inverter to get the pump (compressor) started as fast as line power, you have no problem. If you are wondering, open the back side panel and have someone shift the temperature control until it starts. If it starts right up, you are good. You probably have enough house bank (2*GC2 is good) and a 1500+VA inverter. You are good there.
The 50° and 85° are another issue that won't matter much. The 50° is probably where the automatic defrost won't work and the 85° just means it will have to work harder and maybe the ice cream will be soft.
Now, there is a little Gotcha here....
RV reefers are all cooled by a rear coil system and outside air that comes in the back panel and goes out the roof vent. No residential is made that way these days. The cooling is done on the sides of the unit, so you can't build it in tight. It will want an inch or more of clear space on both sides that is open to the living space. This also means that the outside air can come around the sides of the installed unit. That, you have to figure out on your own because I can't see what you have there.
You may also have to invent some way to keep the door(s) closed.
I have had good success with three installations (after the first that was not so good, but still worked).
Matt
