Chris_Bryant
Aug 18, 2013Explorer II
Most of the older RV ovens used a 2 stage pilot which has a small standing pilot and a higher heater pilot. The thermostat just controlled the pilot size, and the higher heater pilot heated a small bulb hooked to the safety valve via a small capillary tube, which opened the valve letting LP flow. These were done away with because of the mercury in the valves.
The new models use a standard thermocouple type system- push and hold to light. A common problem is the knob bottoming out on the panel before it can be depressed far enough. The fix being taking the knob off and stuffing a small wad of paper in it to raise it a bit.
Look around the DIY forum for a couple of people who have installed electronic lighters on their ranges- a great mod.
Here you go electronic ignitor install.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
