filrupmark
Dec 03, 2013Explorer
Im having the same problem, Pilot lights ok and when you adjust it to say 350 degrees the pilot increases but not quite enough to heat up the thermocouple to let the burner light.I found a brass screw behind the thermostat knob and that screw is the pilot flame size adjustment. Guess what mine is turned up to max already. I checked the gas pressure and it is at 11.5" Which is good. Does any one know if there is a orfice at the pilot that may need cleaning.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
