otrfun
Nov 27, 2014Explorer II
bobinyelm wrote:IMO, you should be much more concerned about the LRA (locked rotor amp) rating, and not the BTU rating. The LRA rating determines whether your Honda EU2000i will start a given a/c unit.
I am looking for a power-miser roof A/C to replace my 13,500 BTU roof air the PO of my well-insulated BigFoot truck camper installed (throwing out the perfectly good OEM 7700 BTU unit).
He did it for "instant cooling" with hook-up campgrounds, but I want a unit that my little Honda 2000i genset can easily handle boondocking.
The smallest I can currently find is a Coleman 9200 BTU unit, so I'm hoping someone here may have an alternative.
Bob
A Honda EU2000i has the ability to "run" most 13,500 BTU a/c units---IF it could "start" them. Most 13,500 BTU a/c units only need approx. 10-14 amps to "run". Unfortunately, many of these same 13,500 BTU a/c units need 55-65 of inrush (startup) current to "start". The Honda EU2000i can output approx. 50 amps of inrush with the ECO mode on, and approx. 53 amps of inrush with the ECO mode off.
To my knowledge these two, latest generation 9xx series Coleman Mach Power Saver a/c units have the lowest LRA ratings of any 11,000 or 13,500 BTU a/c units on the market:
Coleman 11,000 BTU
Coleman 13,500 BTU
A Honda EU2000i will easily start and run the 11,000 BTU 482x7-9xx (LRA 41.5 amps), and has very, very good chance of starting and running the 13,500 BTU 482x8-9xx (LRA 50.5 amps) . . . with the ECO mode on.
Do not confuse the 9xx series with the previous generation Coleman Power Saver 8xx series. The 8xx series have a much migher LRA.
My two cents . . .
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
