mobeewan's avatar
mobeewan
Looking for recommendations for inspection camera
I'm looking to by a good waterproof inspection camera similar to one of these in the $100 to $200 range.
Any recommendations? Anyone have one of the Harbor Freight cameras in the link above?
I discovered a roof leak from the bathroom skylight in my TT Monday (5 inches of rain) and more on the way. Took down the inside garnish and water was dripping from the rubber roof material where it had been cut for the opening, tucked and stapled to the wood framing. the leak is between rubber roof and the skylight flange. I wadded up some small pieces of paper and stuffed them between the rubber roof material and wood framing to make a drip edge so the water would not continue to wet the wood and ceiling paneling.
There is no grey water staining on the wood framing so the leak looks fresh. Was thinking about pulling the inside ceiling panels loose around the opening and peeking inside to make sure the insulation hasn't gotten wet yet and see if the water has migrated towards the outer wall. Will be pulling the skylight and resealing and Eternabonding when the weather permits.
I've been wanting an inspection camera anyway and have needed one in the past, so it may come in handy now to check the ceiling for water damage without tearing down the paneling.
  • I have a Ryobi from Home Depot. Cheap, works great and the battery can sit charged up for 6 months to a year, and it still works fine.
    $69.00
    http://www.cpooutlets.com/factory-reconditioned-ryobi-zrrp4205-tek4-digital-inspection-scope/ryorzrrp4205,default,pd.html?zmam=31282435&zmas=47&zmac=664&zmap=ryorzrrp4205&ref=outletscipla&ci_src=17588969&ci_sku=ryorzrrp4205&gclid=CLDh27qB1MACFSdk7AodbWAAXQ
    Sorry, never learned how to do clicky's
  • If you buy one from HF, make sure you use a 20% (or more) off coupon. :)
