time2roll
May 25, 2020Nomad
Dusty R wrote:My old tv with the 12v brick was actually 12.6 volts IIRC. Screen would get scary bright at 14.4 boost charging the battery and the tv would give a beep tone when the furnace etc would pull the voltage below 12.4 volts. It was a great idea in theory but impractical for actual use.
You guys that are bad mouthing 12 volt TVs. Most all TVs on the market today have a wall wort, If you look at that wall wort you will see that it's output is 12 volt.
300 watt sine wave inverter was the solution to work in all conditions. Sine wave also solved the lines on the screen when using a square wave inverter.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
