Almot
May 24, 2014Explorer III
Another solution (after you will have solar up and running, of course).
Dump Honda 2000 and get Honda 3000 or whatever wattage is necessary to run A/C. Because you will mostly need it for A/C. Or keep on running your Onan on such occasions.
Are you planning to run 5000W generator in the morning only to run a microwave and make a coffee, with 420W solar, do I read it correct? On a sunny day you won't need a generator for that. This is what inverter is for. On a dark day, and on the 2nd dark day, you won't need a generator for that either. On the 3rd dark day, if it's still dark, you will need "a" generator. But when it comes to A/C, you need more than 2000W, don't know how much more, depends on your A/C.
