CT_WANDERER
May 24, 2014Explorer
Almot wrote:
Another solution (after you will have solar up and running, of course).
Dump both Honda 2000 and Onan, and get Honda 3000 or whatever wattage is necessary to run A/C. Because you will mostly need it for A/C. 5000W generator in the morning only to run a microwave and make a coffee, no kidding ? On a sunny day you won't need a generator for that. This is what inverter is for. On a dark day, and on the 2nd dark day, you won't need a generator for that either. On the 3rd dark day, if it's still dark, you will need "a" generator.
So sometime, I am going to have to change my 300 watt PSW inverter for something a little bigger.
