Old-Biscuit
Dec 06, 2016Explorer III
NO.........
There is NOT a 'sway bar' kit for 5th wheel.
NOT needed PLUS it would be an engineering cluster mess
So are you towing NOSE HIGH
Does TH sit level when hooked up to truck?
Swaying issues with a 5th wheel are due to tail heavy/nose light.
CAT Scales to see what real pin weight is????
My 5vr is 13/4" tall and tows very stable even in high side winds.
Height isn't issue (13'6" limit)
Width isn't issue (102"-96"=6")
Check/verify
Pin Weight
Tow Level
Tail heavy
Reese Sidewinder set up properly....correct torque on turret bolts and correct wedge being used
Check/verify
Pin Weight
Tow Level
Tail heavy
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
