enblethen
Sep 04, 2019Nomad
Your clearance and running lights enter through the umbilical normally on the brown wire. In the box, you maybe able to separate the clearance lights from tailights to isolate where the problem is.
By chance had you replaced a tailight/brake light bulb? Make sure it is the proper lamp if you have! I have seen 1141 bulbs stuck in sockets for 1157 dual filament lamp.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
